Spark Plugs - Page 2 - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 05-22-2006, 03:43 PM   #11
MV1
No MVs in the Registry
MV1's Avatar
Arrow How hard are they to change?
How much work is involved in changing the plugs? Last time I had the plastics off I couldn't really even see them. When I do change them I would like to go iridium. I guess I will need the NGK CR9EIX's for the F4-1000 . correct?
MV1 is offline   Reply With Quote
Old 05-22-2006, 03:51 PM   #12
eMoto UK
MVAgusta.net Sponsor
eMoto UK's Avatar
Default
Hi there,
Requires taking half the bike apart!
1) Fairings and bellypan off
2) Frame/Tank panels off
3) Injector covers off
4) Front nose cone off
5) Electrical/Relay covers off
6) Air tubes off
7) Tank off
8) Airbox out
9) hey presto!
First time takes some working out, there after it is a relatively easy to take apart.
eMoto UK is offline   Reply With Quote
Old 05-22-2006, 03:55 PM   #13
MV1
MV1's Avatar
Angry wwhawah-what!?!
Wow.
Old 05-22-2006, 03:57 PM   #14
MV1
MV1's Avatar
Default
That sucks.
Old 05-22-2006, 04:08 PM   #15
eMoto UK
eMoto UK's Avatar
Default
That sucks.
Know where your coming from. But after you do it once you can do it over and over at ease.
If you do go ahead and start taking it apart, becareful when disconnecting the fuel connectors (x2), ideally you want another person to help you lift the tank while you disconnect. Also when removing the injector covers, careful not to loose the rubber wellnuts, if you do, do not start the bikes, they will be sitting inside the airbox or on top of throttle bodies.
All the best
eMoto
Old 05-22-2006, 04:16 PM   #16
Greeneggs&ham
Living the Dream
MV in the Registry:
[F4 1000]
Greeneggs&ham's Avatar
Default
is there a good time to change from stocks to Iridium. i have been thinking about doing that but wondered if they would change my custom map at all? Thanks.
__________________
Get busy livin, or get busy dyin
Motorcycle Art!
You live more in 5 minutes on a bike like this, going
flat out, than most people live in a lifetime.
Greeneggs&ham is offline   Reply With Quote
Old 05-22-2006, 04:39 PM   #17
style_one
MV in the Registry:
[F4S 750]
style_one's Avatar
Default
i just did this last week. new plugs won't change your map because it won't change the timing and they can't change your air/fuel mixture either. the only thing it should do is make your burn more consistant assuming the plugs are better. let's see if someone betters my analysis....
only trick i had was getting the old plugs out. my spark plug socket was a little too fat due to gasket material making the hole a little tight. patience is always the virtue.
style_one is offline   Reply With Quote
Old 05-22-2006, 05:34 PM   #18
MV1
MV1's Avatar
Arrow
Thanks for the heads-up guy's. In all seriousness I kind of figured it wouldn't be a 1-2-3 thing, but the tips you gave should help.
pk
Old 05-22-2006, 06:12 PM   #19
JamesC
MV in the Registry:
[F4S 750]
JamesC's Avatar
Default
Today
Only the cost of 4 CR9EIX plugs and 4 wellnuts
Unless you buy and use an ignition tuner like the powercommander add-on or a plasmabooster you won't be too concerned about ignition and spark - your eprom will take care of that, as style said.
John/airfuel, do you have occaision to work with these PCIII 'ignition modules' and if so, on an MV as of yet? Interested to hear more about this if so.
__________________
JamesC
www.MVFAQ.blogspot.com
JamesC is offline   Reply With Quote
Old 05-22-2006, 07:04 PM   #20
airfuel
airfuel's Avatar
Default
Originally Posted by JamesC
Today :
Usually, optimizing timing on a stock bike gives small gains. Usually not worth the long dyno time needed for trial and error tuning. It is best for engines that have extensive work done to them. High compression pistons, race gas, head work etc.
I do it plenty on Harleys as it is built into the PC's for those bikes, but these guys do major work on the motors and tweaking the timing helps.
Never have done it on an MV.
John T
airfuel is offline   Reply With Quote
vB code is On
HTML code is On
Forum Jump
