Joe;
the Muzzys will always pull air through the radiators.....but there could be a clearance problem, if they are on upside down.....the pitch angle doesn't change ......its like a bolt from either end, its still a right hand thread
sold my pair of Muzzy fans to MVista, i only need the upper one .....oil cooler is going in, in place of the lower with a Ducati fan on it and Lee's 2nd fan on the upper radiator....but without his switch mod.....
Joe;
the Muzzys will always push air through the radiators.....but there could be a clearance problem, if they are on upside down.....the pitch angle doesn't change ......its like a bolt from either end, its still a right hand thread
Actually the whole thing worked out a treat - ceramic coated headers, muzzy, impeller & engine ice. +1 on the clearance problem that Noel spoke about if they are the wrong way, so you really can't get them wrong because you'll realise it once you spin them.
Thanks again Noel
The only way that they will blow instead of suck is if you get them to spin in the opposite direction which you can't do by simply bolting them in.
gee, folks just thought i'd let you know one of my sidelines is designing and building acrobatic sex devices......you know, swinging from the ceiling and wall restraints, if you know what i mean...........LOLOL
Noel,
Now that you've divulged your sideline buisness I'm sure Randy will be knocking down your door to have one of your contraptions modified for some brutie on brutie action to have fitted up in his "Toy Box"
the dealer told me that in the f4 rr (mine is 2012 model) the second fan is only activated at higher temperatures,,,,, so at not so hi temperatures...only 1 is working.....
you guys confirm this ?
I guess all things are possible but it doesn't make much sense . Have a look at the wiring diagram. Are their two cooling fan relays or one ?
joe
Related Threads
MV Agusta Forum
1M posts
55.7K members
Since 2005
A forum community dedicated to MV Agusta motorcycle owners and enthusiasts. Come join the discussion about troubleshooting, maintenance, performance, modifications, classifieds, and more!
