my sr 750 has started idling rough when it gets hot. it only seems to do it in stop start traffic.it's going to the mechanic next week i just want to try and narrow down what could cause it
Don't worry, the 750's are sound bikes and work well when everything is right, obviously something is wrong here, it's just a process of tracking it down.
First as it's a 750 it is a few years old now. Some stuff will be worn or perished or needing adjustment. I assume you have downloaded the manual and have some degree of mechanical knowledge.
Can you describe the symptoms in more detail for me, my 750 when stuck in city traffic does get up around 102 and the engine note changes as the cooling fans kick in (yours should have twin rads).
Mine does run a bit fluffy here and requires a bit more of a handful and revs to move off easily, all returns to normal when you get some air flowing through the rad this is all normal stuff, is yours like that?
When did the bike last have a TPS calibration check, a fuel filter replaced, and the throttle bodies balanced/synched?
You have made a thorough inspection of the fuel lines under and inside the tank? Did you clean the gauze filter on the pump body, all this is simple stuff and in the manual, rubber does degrade if in doubt get new lines.
A PC111 will help the bike but not solve the high temp issue, it is always going to get a little rougher when over 102 degrees plus.
Did you replace the fan relays and checked they work, these are small black relays four pin type about an inch long by half inch. And finally check the breather pipes from the tank filler cap down through the pump body are clear and not blocked, then see how she runs.
this is what i've done so far
changed the injection air sensor it seems to have improved idle
new fan sensor the fans now work and you can hear the map change when they come on
tps checks ok
new air filter and spark plugs
power commander and mapping it now runs a lot better than it did it still needs more mapping down low but we couldn't do it because of the rough running/idle
short trips it runs fine but if you ride for 20 to 30 minutes it starts running rough and idling rough even if the temp sits around 85c
i think the coils may be breaking down but i'm not sure
thanks rob:f4:
here's the dyno chart stock air filter and exhaust
Does sound like one of the two coil packs is going down, a good diagnosis tool if you have a set is to connect up the throttle balance gauges and run the bike until she gets hot. the balance gauges will indicate on which cyl or cyl's the miss fire is occurring, works for me.
If it is a coil double check leads and caps for splits etc.
got coils from cag put them in today it seems to have fixed it i went for a 30 minute ride in stop start traffic and it ran perfect
many thanks to cag for the parts and thanks to everyone else that helped
Related Threads
MV Agusta Forum
1M posts
55.7K members
Since 2005
A forum community dedicated to MV Agusta motorcycle owners and enthusiasts. Come join the discussion about troubleshooting, maintenance, performance, modifications, classifieds, and more!
