#1 |
Member
Hi guys my 312r has just failed its first UK MOT due to having a non UK spec headlamp ( to say im disappointed is an understatement )
i have had the bike from new and the light is as fitted from the factory ...has any one else had the same problem ?chris |
| Sponsored Links | |
Advertisement |
#2 |
Is the bike an import? Did you get it from DK Motorcycles? They specialise in imported bikes at lower prices.
It could be just that the light is pointing towards the wrong direction for European right hand side driving in which case it can be easily re-aligned. I would take it back from where you got it and get them to correct and re-mot it for you. I have a 2007 F4 1000R and it has had a few mots without any issues. Danny |
#3 |
Member
hi Danny i purchased the bike from Bennts mc i am awaiting a return phone call as i type apparently its the lens that's the problem i have 3 part numbers no idea at present which one is uk spec
0000487 Lens Assy Lower Beam Polyellipsoidal 0000488 0000489 |
#4 | |
Good luck buddy! Danny |
#5 | |
No MVs in the Registry Join Date: Oct 2010
I don't know if MV made a mistake back then in 2000, or were desparate to fulfill the orders and knew what they were doing. One thing the dealer said was that they still had some of these Uk spec parts left, so I suspect a batch was sent over, maybe just to sort out this problem? |
#6 | |
![]() Join Date: Nov 2009
This is a UK projector I believe...I did have a peek inside a USA Headlamp a while back and that low beam projector also had UK stamped on it..! joe Last edited by gotojoe : 05-05-2012 at 03:23 PM. |
#7 |
there are three different version of the head lamp:
right hand drive left hand drive and USA (does that mean they drive all over the place?) as far as i can read the parts catalog, it should be part number 800094522 for left hand drive, which you have to replace in your lamp, or 800094507 for the full headlamp. |
#8 |
Do yours have a cut off on the side that illuminates signs? Ours don't and that was the difference between them on my BMW. Ours are level across the horizon.
If that is the case anyone want to ship me a light? I much prefer the right hand rise. |
#9 | |
![]() No MVs in the Registry Join Date: May 2006
Hope that helps if not give DK a call I'm sure they'll be very helpfull, In fact now I think about it a friend of mine who didn't purchase his MV from DK called them with the same problem, they said take the head light unit of and bring it down to the garage and we'll change it while you waite for a small charge. |
#10 | |
Member
No MVs in the Registry Join Date: Jan 2011
As the original dealer was DK I hope that they just post me a UK one. We will see on Tuesday.. |
