monobloc brembo Bleeding - MVAgusta.net
post #1 of 9 (permalink) Old 05-06-2012, 02:07 AM Thread Starter
Mungee's Avatar
I just fitted a set of monoblocs and am wondering do they have 2 bleed nipples or the one.
As I have used my old bolt and nipple where the lines come into the caliper mine has 2 now, so do I need to bleed that side?
The gold series only had the one nipple.
My car's brembos have 2 one on each side fo the caliper.
Help please.
Mungee is offline
post #2 of 9 (permalink) Old 05-06-2012, 03:05 AM
You bleed the one furthest away from the reservoir first, then the one on your original line, working back towards the M/C.
post #3 of 9 (permalink) Old 05-06-2012, 03:06 AM
The_castle's Avatar
Hmmmm.
So, you're not talking about cast monoblocs are you?
Pictures courtesy of JDS, sure he won't mind me using them.
Any pics of yours?
The_castle is offline
post #4 of 9 (permalink) Old 05-06-2012, 03:55 AM Thread Starter
Mungee's Avatar
Ok thanks guys, I have fitted the above pictured brakes.
My question is on bikes fitted with these brakes does the banjo bolt that fixes the brake line to the caliper have a bleed valve in it?
If so then you have to bleed both sides, if not it only has the one bleed valve as per above.
Mungee is offline
post #5 of 9 (permalink) Old 05-06-2012, 04:01 AM
Thumbs up
That's what I said.
post #6 of 9 (permalink) Old 05-06-2012, 09:47 PM
Question
Help please.
How did you go Mungee, sorted ?
post #7 of 9 (permalink) Old 05-07-2012, 05:47 AM Thread Starter
Mungee's Avatar
Thanks Donsy I appreacite your comments and follow up but it is almost impossible to get into the other bleed vale, will keep trying.
My other question to other who have the later bikes did MV fit a bleed valve on the brake line inlet as they would have similar issues?
Mungee is offline
post #8 of 9 (permalink) Old 05-07-2012, 08:44 PM
Smile
Hi Mungee
The problem is that you're using the Old lines on the new calipers, most blokes change individual brake lines and no bleed nipple on the Banjo, or you just get Banjo fittings without bleed nipples on them. The 1078RR has no bleed nipples on the Banjo fittings.
Pictures will help too man, I've done this for a couple of guys and have never had a problem using either of those methods.
post #9 of 9 (permalink) Old 05-07-2012, 09:30 PM Thread Starter
Mungee's Avatar
Thanks Donsy you have answered my question and put me to ease.
I have bought the new 1078RR lines and fitted those but re-used the banjo/bleed off my old calipers (with new crush washers) thus giving me the question around do I need to bleed that one - or does a 1078 come with that 2nd nipple.
Answer is no need to bleed and no it does not come with one.
Thanks to all.
Mungee is offline
Human Verification
