rear brake reservoir - MVAgusta.net
post #1 of 14 (permalink) Old 01-09-2017, 07:56 PM Thread Starter
number2's Avatar
has anyone attempted insulating the reservoir to keep it from overheating.
number2 is offline
post #2 of 14 (permalink) Old 01-09-2017, 08:46 PM
Several of us have George - but remember it does not enhance the braking performance, it just prolongs the brake fluid life, re-locating it is a more effective way and allows for easy access.
Insulating the master cylinder helps much more in preventing brake fade, as well as following a proper bleeding procedure.
post #3 of 14 (permalink) Old 01-09-2017, 09:18 PM Thread Starter
number2's Avatar
easy access would be very nice. Geez what a pain to get to it now
number2 is offline
post #4 of 14 (permalink) Old 01-10-2017, 02:25 AM
Cool Example
This is one I did some years ago George - Later on I used smaller reservoir and installed where the toolbag is now lying, just because this was experimental.
On the new F4's it's behind the rearset/frame plate, might be worth looking at, I don't use a reservoir at all, just a piece of tube.
post #5 of 14 (permalink) Old 01-10-2017, 09:53 AM
gordo555's Avatar
+1 on that!
2006 Brutale 910S.... runs like a scalded assed ape.
gordo555 is offline
post #6 of 14 (permalink) Old 01-10-2017, 01:25 PM Thread Starter
number2's Avatar
I am going to get a longer piece of hose and try relocating it to the left side subframe close to where the lock is for the tail section
number2 is offline
post #7 of 14 (permalink) Old 01-10-2017, 05:58 PM Thread Starter
number2's Avatar
what spec is the hose running from the reservoir to the master cylinder
number2 is offline
post #8 of 14 (permalink) Old 01-10-2017, 06:43 PM
@number2 - this stuff George https://www.kurveygirl.com/shop/inde...uol8jignml27p5
post #9 of 14 (permalink) Old 01-10-2017, 08:19 PM Thread Starter
number2's Avatar
Thanks Dons. Just ordered some
number2 is offline
post #10 of 14 (permalink) Old 01-10-2017, 08:32 PM
Thumbs up
@number2 - Note that I put some heat reflecting sleeve over the tubing George, easy to do and you can buy various sizes at auto shops.
Human Verification
