2013 F4 1000 Stalling and Speedo not working - MVAgusta.net
 3Likes
post #1 of 12 (permalink) Old 01-09-2017, 02:52 AM Thread Starter
Clay1001's Avatar
Major issues today......
After having my bike tuned to perfection and it becoming a pleasure to ride suddenly today it is having major issues.
I was riding it around this afternoon and everything was great then suddenly the Speedo started giving false reading and the bike stalled.
I turned the key off and restarted it and off I went then it happened again. While riding it started to stall if I pull the clutch in the engine stays alive but when I go to release the clutch while still moving the the engine dies.
I had to restart the bike numerous times to cripple it home. Now the Speedo does not work at all and just reads zero. Everything else is working fine. No errors on screen and no warning lights but the bike just stalls while riding
I have just got the girl preforming so well and this happens Grrrrrrrr
Can anyone shed so light on this issue please....
Thank you in advance
Clay
IF LIFE THROWS YOU A CURVE, DROP YOUR KNEE AND RIDE THAT BITCH
Clay1001 is online now
post #2 of 12 (permalink) Old 01-09-2017, 07:24 AM
Clutch in or stalling says to me have a look at the safety switch on the sidestand..
george4337 likes this.
ADELAIDE Australia
albymangled is offline
post #3 of 12 (permalink) Old 01-09-2017, 09:01 AM
number2's Avatar
have you added any aftermarket systems lately which required the battery to be disconnected? Maybe a Power Commander? You may have a bad ground. Remove the battery cables and clean them then secure them.
number2 is offline
post #4 of 12 (permalink) Old 01-10-2017, 05:27 AM Thread Starter
Clay1001's Avatar
Location of Speedometer Sensor in 2013 F4 1000
Can anyone tell or show me where the speedo sensor os on my 2013 F41000 as I am have issues with my speedo.
Thank you
Clay.
post #5 of 12 (permalink) Old 01-10-2017, 06:34 PM
It's in the workshop manual Clay, electrical section fault finding has a good testing procedure. It's at the rear wheel, behind the brake disc. Check that and sidestand and clutch switches.
post #6 of 12 (permalink) Old 01-10-2017, 11:01 PM Thread Starter
Clay1001's Avatar
Thank you Donsy
I just wasn't sure whether the sensor was on the front wheel or the rear wheel.
I only have the MY10 Manual but own a MY13 F4 and having issues downloading that manual
Cheers Clay
post #7 of 12 (permalink) Old 01-11-2017, 12:14 AM
@Clayton1001 - Check the notification at the second from top of this section, it's a "sticky" with a red exclamation mark next to it mate, go the my last post in that notice - Maintenance & Tech. Issues (All 4 Cyl. Models) - MVAgusta.net
Also read the "Announcement" right at the top called "Read the Please RE MV Manuals"
And there's two here, in the sticky second from the top in your model section - Workshop Manuals for most MV's, for all to use.
post #8 of 12 (permalink) Old 01-11-2017, 12:27 AM Thread Starter
Clay1001's Avatar
Thank you Mate
I have it now. I appreciate your help and patience.
post #9 of 12 (permalink) Old 01-11-2017, 03:20 AM
Good luck mate, sounds like a bad switch or connection, bad it could be a bad sensor too.
post #10 of 12 (permalink) Old 01-12-2017, 04:14 PM
Clay;
Go to the electrical troubleshooting guide in the service manual
i'm not PC either
email, PayPal;
Human Verification
