'05 Brutale Fork Compatability - MVAgusta.net
post #1 of 5 (permalink) Old 12-11-2012, 02:23 PM Thread Starter
exbike's Avatar
Hi, looking for some forum wisdom here. I have a '05 brutale 750s with 50mm marzocchi fork. I bought it used, and have some serious pitting and chrome flake on both sliders. I am looking into re-chrome or DLC, but the cost of the repair is approaching the cost of a used set.
As I search eBay, etc., what will fit in my '05 triples? Will the 49mm showa stuff fit, or do the showas have a specific triple clamp that is unique? If the showas do fit, will my wheel and calipers bolt up? What about mv forks with radial brake designs? Besides obviously needing radial calipers, what about wheel and fender compatibilty?
I'm not really looking for a particular setup -- I just want to know what options I might have as I scour for used parts.
Thanks! -matt
exbike is offline
post #2 of 5 (permalink) Old 12-11-2012, 08:10 PM
call or PM CAG
i'm not PC either
email, PayPal;
post #3 of 5 (permalink) Old 12-11-2012, 08:30 PM
Marzocchi and Showa all fit the same triple clamps mate, and as long as you stick with non-radial is will be a easy swap.
To convert to radials you will need axle(spindle), axle nut, calipers etc. There might be a fork length difference but that is easy adjusted.
Mudguards(fender) etc will go straight on.
post #4 of 5 (permalink) Old 12-11-2012, 09:32 PM
You should be able to source a pair of Marzocchis with the axial caliper mounts for under $400.
post #5 of 5 (permalink) Old 12-11-2012, 10:54 PM
Exclamation hahaha
Thanks! -matt
There you go - sorted
Human Verification
