07 battery drain - MVAgusta.net
post #1 of 15 (permalink) Old 11-03-2012, 09:55 AM Thread Starter
V10KLZZ71S's Avatar
07 battery drain
First I had a Shorai in my bike, it sat for 3 months, dead. No way to charge it so I bought a cheapo Autozone replacement, actually I bought 2 and put one in my Yamaha FZ1 at the same time.Rode the MV quite a few times, no problem. FZ1 just sat other than an occassional start up. Anyway, my brutale sat for about 1 month, dead battery. Jumped it off, ran it for about 2 hrs, started up good multible times. Next morning......click click! WTF? Any ideas on what could be causing a drain?
07 Brutale' 910R Arrow Thunder, PCIII,Ferracci chip, CRG mirrors,levers. Scotts, Motovation sliders.
O6 Yamaha FZ1
V10KLZZ71S is offline
post #2 of 15 (permalink) Old 11-04-2012, 08:43 AM Thread Starter
V10KLZZ71S's Avatar
Everything visible is working normal, no light/blinker etc issues which might indicate a spu problem.
***Members here who I was friends with on facebook, I did not unfriend yall, I deleted my FB for good.***********
O6 Yamaha FZ1
post #3 of 15 (permalink) Old 11-04-2012, 04:38 PM
cruiser's Avatar
Is your Alternator going ?
In the Garage today...
'14 H-D Street Glide Rushmore
'11 MV Agusta Brutale 990R Special Edition #81/150
cruiser is offline
post #4 of 15 (permalink) Old 11-04-2012, 05:23 PM
Smile Hi Daryl
Tim might be right, your alternator might not be charging, have a look through the manual and test the charging voltage at the battery.(Easy to do and hopefully all is good here)
The MV's do have a drain problem and will drain a weak or poor quality battery very quickly though.
Make sure you take the bike for at least a good 20min ride and see what it does.
Donsy is online now
post #5 of 15 (permalink) Old 11-04-2012, 06:11 PM Thread Starter
V10KLZZ71S's Avatar
Thanks! I will check that when I get in from the rig.
O6 Yamaha FZ1
post #6 of 15 (permalink) Old 11-04-2012, 06:38 PM
Wills's Avatar
Good idea to keep Battery Tender on when sitting.
Stop Global Whining
Wills is offline
post #7 of 15 (permalink) Old 11-05-2012, 01:04 AM
Thumbs down ?
Wills;
you keep a tender on your car??
1,375,000 mi on bikes and never a battery tender
my '66 Big Block Chevy at 327,000 mi has the original alternator....
a 37 Amp Delco........and a 200 Watt PER channel amp
MVs have a 51 Amp Denso alternator.......controlled by the ECU
i wonder where the problem is?
i put 11,000 mi on my '08 Brutale...... it used a low beam bulb, thats, IT NO PROBLEMS, PERIOD
OK and tires twice......brake pads should be due soon
oh, thats right a Mitch hub and a MicroTec ECU are installed too
i'm not PC either
email, PayPal;
post #8 of 15 (permalink) Old 11-05-2012, 07:15 AM
With all due respect, Noel....those of us who live in colder climes than you fortunates in Cali NEED tenders.
Batteries lose voltage by design over time...we've been through this. Yes, I keep my cars on tenders if I am not going to drive them in a month...the lawn tractor gets one too. I can have batteries last well past their 5 year design life by doing so. Tenders, good ones, are a good idea...and they keep weak batteries ready to go. If you get a really good smart charger, it will also de-sulfate and restore batteries.
Keep your words soft and sweet, for someday you shall eat them....
post #9 of 15 (permalink) Old 11-05-2012, 09:02 AM
I use Battery Tender+ and BT Juniors on all my vehicles. Plug in a BT+ each night on my '95 M3 and unplug it in the morning. The OE Douglas battery lasted 13 years under this regimen. Plug in a BT junior each morning on whichever one of the 14 bikes I'm heading out on that day. Generally get 7 to 10 years service out of the bike batteries. It does get brisk here in the mountains though. -27 degrees F is the nippiest I've seen so far. It also rarely exceeds 85 F on the hottest summer days.
bikefreak47 is offline
post #10 of 15 (permalink) Old 11-05-2012, 02:40 PM
Wills's Avatar
Wills;
you keep a tender on your car?? Which one...the 57 T-Bird, the GTO, the s60R? be more specific.
1,375,000 mi on bikes and never a battery tender I have numerous bikes, and if they sit for weeks the tender goes on. Bring your MV into the cold winter, but remember I won't push your ass to get it running.
a 37 Amp Delco........and a 200 Watt PER channel amp Chevys are like assholes, everyone has one.
i wonder where the problem is? It's always the tools/parts fault, not the mechanic?
i put 11,000 mi on my '08 Brutale...... it used a low beam bulb, thats, IT NO PROBLEMS, PERIOD spell check this
Truth be told since I installed the lithium on the Brute, the charger is rarely required. But a standard battery won't last the winter. Every spring the shop gets numerous calls...won't start, mostly dead batteries that were not charged during the winter. You want to come to Reno and pick up all those bikes to argue your theory? It would make our days much easier
Stop Global Whining
Wills is offline
Human Verification
